Select Help > Sample Data Library and open Semiconductor Capability.jmp.
Select Cols > New Columns.
Type 3 next to Number of columns to add and click OK.
Select the first new column, select Cols, and then select Formula.
Create the formula NPN1/PNP1 and click OK.
Figure 6.11 Create the Formula NPN1/PNP1
6.
Select the three new columns and then select Cols > Standardize Attributes.
8.
Select Substitute Column Reference and leave NPN1 and PNP1 selected.
Figure 6.12 Standardize Properties Options
9.
In the data table, PNP2 comes after PNP1.
In the data table, NPN2 comes after PNP2.
Figure 6.13 Resulting Data Table
Note: Some columns in Semiconductor Capability.jmp were deleted to show the new columns X, Y, and Z in Figure 6.13.
Help created on 10/11/2018
