For example, the Blood Pressure.jmp sample data table contains blood pressure measurements taken on five subjects three times each day, over a period of three days. You want to find the log of each blood pressure (BP) column.
Select Help > Sample Data Library and open Blood Pressure.jmp.
Select Cols > New Columns.
Right-click Column 1 and select Formula.
6.
Select BP 8M.
7.
Select Transcendental > Log.
8.
Column 1 now contains the log of the BP 8M column. You want the rest of the empty columns to contain the log of the remainder of the BP columns.
10.
Select Cols > Standardize Attributes.
11.
In the Standardize Properties panel, click Column Properties and select Formula.
12.
Select the check box next to Substitute Column Reference.
13.
Leave BP 8M selected.
14.
Now all of the new columns are populated with the log of the BP columns, in the order in which they appear. Column 1 contains the log for BP 8M, Column 2 contains the log for BP 12M, and so on.
Help created on 10/11/2018
