Open the VA Lung Cancer.xls file in Excel. This file is located in the Sample Import Data folder.
In JMP, select File > New > Data Table to create an empty table.
Select Edit > Paste with Column Names to paste the data and column headings.
If the data that you are pasting into JMP does not have column names, then you can use Edit > Paste.
Help created on 10/11/2018
