Select File > Open.
Click Open.
Select File > Open.
Navigate to the Samples/Import Data folder.
Select Team Results.xls.
Click Open.
Next to Column headers start on row, type 3, and press Enter. The column headings are updated in the data preview. The value for the first row of data is updated to 4.
Deselect Use for all worksheets in the lower left corner of the window.
Select Ungrouped Team Results in the upper right corner of the window.
7.
Click Import to convert the spreadsheet as you specified.
See Copy and Paste Data and Import Microsoft Excel Files in the Using JMP book for more information about importing Excel files.
Select File > Open.
Select Animals_line3.txt.
Click Open.
Figure 1.12 Initial Preview Window
6.
Enter 3 in the File contains column names on line field.
7.
Enter 4 in the Data starts on line field.
8.
Click Next.
9.
Click Import.
The new data table has columns named species, subject, miles, and season. The species and season columns are character data. The subject and miles columns are continuous numeric data.
Help created on 10/11/2018
