Notes:
To copy all text (no graphs) from the active report window as unformatted text, select Edit > Copy As Text. On the Macintosh, select Edit > Copy As Text.
To copy anything other than a graph, right-click and select Edit > Copy Picture. For example, to copy a report, right-click on the bar containing the report title and select the option.
The Reports preference Transparent background in report PNG images determines whether reports that are saved as PNG images have transparent backgrounds. The preference is deselected by default.
Help created on 10/11/2018
