Figure 9.5 shows some of the items that you can add to a journal.
Figure 9.5 Example of a Journal
Tips:
Journals support GZ compression to reduce file size. See General in JMP Preferences. This can be particularly helpful if large data tables are embedded in the journal.
Help created on 10/11/2018
