db = Create Database Connection( "Connection String With Password" );
Execute SQL( db, "SQL statement", <invisible>, <"New Table Title"> );
Close Database Connection( db );
Using these three functions, you can open a connection, call Execute SQL several times, and then close the connection. Create Database Connection returns a handle for use in Execute SQL and Close Database Connection.
dbc = Create Database Connection(
	"DSN=dBASE Files;DBQ=$SAMPLE_IMPORT_DATA/;"
dt = Execute SQL( dbc,
	"SELECT HEIGHT, WEIGHT FROM Bigclass", "NewTable"
Close Database Connection( dbc );
	"DSN=dBASE Files;DBQ=$SAMPLE_IMPORT_DATA/;UID=MyDatabase;pwd=MyPassword");
Main Menu( "Open Table" );
Note: Execute SQL() creates a connection string that includes the cleartext password in the resulting data table. We encourage you to create the SQL query in Query Builder and then run the query in JSL. Then the password is not included in the data table.
Help created on 10/11/2018
