The Query() function enables you to manipulate JMP data tables using SQL statements. The SQL statement is the only required argument to Query(). However, most interesting SQL statements refer to one or more data tables. Any data table that the SQL statement refers to must be passed in using a table reference argument.
result = Query( dt, "SELECT * FROM 'Big Class' WHERE age > 14;" );
result = Query( Table( dt, "t1" ), "SELECT * FROM t1 WHERE age > 14;" );
Using Table() to alias your data tables also enables you to write SQL statements for multiple queries with tables that have different names without rewriting the statements.
If you want the data table that is produced by Query() to be either private or hidden, you can pass either Private or Invisible as arguments to Query().
result = Query( dt, invisible, "SELECT * FROM 'Big Class' WHERE age > 14;" );
The Query() function normally returns the result of the query as a JMP data table. However, sometimes you might write a SQL query that returns a single value; you would rather have Query() return that value instead of placing the value in a JMP data table. You can do that by passing the Scalar argument.
result = Query(
	Table( dt, "t1" ),
	Scalar,
	"SELECT AVG(height) FROM t1 WHERE age > 14;"
Help created on 10/11/2018
