JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability and Survival Methods •
Destructive Degradation
• Destructive Degradation Platform Options
The Degradation Data Analysis red triangle menu provides the following options:
Graph Options
Provides options for modifying the platform graphs.
Shade
Turns the shading on or off. By default, the upper and lower bounds of each shaded band at a given value of time correspond to the 0.025 and 0.975 quantiles of the distribution of Y.
Shade Coverage
If shading is on, you can enter a proportion to increase or decrease the amount of shading coverage.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
Help created on 10/11/2018
