JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Enter and Edit Data
Organize Data
• Edit Column Names
Edit Column Names
To edit a column name, select the column and begin typing. You can also edit the column name in the Column Info window, or select the header and press Enter.
Help created on 10/11/2018
