JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP • Enter and Edit Data
Enter and Edit Data
Perform Basic Data Table Tasks
After you import data into JMP or create a new data table, you can format your data to prepare it for analysis.
This chapter contains the following information:
Change formatting for numeric values
Add, delete, and select rows and columns
Use the Row Editor to navigate within rows and edit rows
Create scripts that are saved to the data table
Figure 3.1
The Rows and Cols Menus
Contents
Enter Data
Copy and Paste Data
Add Rows
Add Columns
Fill Columns with Sequential Data
Replace Missing Values with Previous Values
Enter Cell Formulas
Select Rows
Locate Next and Previously Selected Rows
Select Columns
Select Columns in a Data Table
Select Columns in the Columns Viewer
Locate Next and Previously Selected Columns
Select Cells
Resize Rows and Columns
Organize Data
Delete Rows and Columns
Rearrange Columns
Group Columns
Move Values
Color Cells
Edit or Delete Cells
Edit Column Names
Hide and Exclude Rows
Exclude Rows
Hide Rows
Exclude Columns
Hide Columns
View Patterns of Missing Data
Find and Replace Cell Values
Use the Row Editor to Edit Cells in a Row
Pop-Up Menus for Rows and Columns
Compare Data Tables
Assign Characteristics to Rows and Columns
How to Find Rows and Columns Options
Label Rows and Columns
Assign Colors or Markers to Rows
Create Color Themes
Delete Custom Color Themes
Select Matching Row State Cells
Delete Row Characteristics
Lock Columns in Place
Restructure Data
Make a Column into Multiple Columns
Make Indicator Columns
Combine Columns
Compress Selected Columns
Make Binning Formula
Convert Labels to Codes and Codes to Labels
Make a New Formula Column
Transform Columns
Recode Data
Edit the Data Table
Change Table Names
Lock Tables
Compress Tables
Use Table Variables
Create and Save Scripts
Help created on 10/11/2018
