Specify a value for the difference you want to detect that is applied to Anticipated Coefficients in the Power Analysis report. The Anticipated Coefficient values are set to Delta/2 for continuous effects. For categorical effects, they are alternating values of Delta/2 and –Delta/2. For additional details on power analysis, see Power Analysis.
