This example uses the Failure3.jmp sample data table, which contains the common causes of failure during the fabrication of integrated circuits. Examine the causes of failure and when it occurs.
Select Graph > Legacy > Treemap.
Click OK.
Figure 10.18 Failure Modes
From Figure 10.18, you observe the following:
