Using the Cities.jmp sample data table, examine the distribution of different pollution measurements (ozone and lead) across selected cities in the United States.
Select Graph > Legacy > Treemap.
7.
Click OK.
Figure 10.16 OZONE Levels for Selected Cities
From Figure 10.16, you observe the following:
Next, examine lead levels in the selected cities. Perform the same steps as before, but substitute OZONE with Lead for the Coloring variable.
Figure 10.17 Lead Levels for Selected Cities
From Figure 10.17, you observe the following:
