Select Analyze > Fit Y by X.
Click OK.
6.
From the red triangle menu, select CDF Plot.
Figure 6.35 Example of a CDF Plot
The levels of the X variables in the initial Oneway analysis appear in the CDF plot as different curves. The horizontal axis of the CDF plot uses the y value in the initial Oneway analysis.
