JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis •
Oneway Analysis
• Additional Examples of the Oneway Platform
Example of an Analysis of Means Chart
Example of an Analysis of Means for Variances Chart
Example of the Each Pair, Student’s t Test
Example of the All Pairs, Tukey HSD Test
Example of the With Best, Hsu MCB Test
Example of the With Control, Dunnett’s Test
Example of the Each Pair Stepwise, Newman-Keuls Test
Example Contrasting Four Compare Means Tests
Example of the Nonparametric Wilcoxon Test
Example of the Unequal Variances Option
Example of an Equivalence Test
Example of the Robust Fit Option
Example of the Power Option
Example of a Normal Quantile Plot
Example of a CDF Plot
Example of the Densities Options
Example of the Matching Column Option
Example of Stacking Data for a Oneway Analysis
Help created on 10/11/2018
