JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing •
Contour Plots
• Example of a Contour Plot
To create a contour plot, you can use either the Contour platform or Graph Builder. This section provides examples for both.
To see the example using the Contour platform, see
Example Using the Contour Platform
To see the example using Graph Builder, see
Example of a Contour Plot in Graph Builder
Help created on 10/11/2018
