Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Y by X.
Select weight and click Y, Response.
Select age and click X, Factor.
From the red triangle menu, select Compare Means > Each Pair Stepwise, Newman-Keuls.
Figure 6.22 Example of Means Comparisons Report for Each Pair Stepwise, Newman-Keuls
In Figure 6.22, the Connecting Letters Report shows that Level 17 is significantly different from all other levels except 16 and 15.
Help created on 10/11/2018
