This example uses the Big Class.jmp sample data table. Examine if the difference in height between males and females is less than 6 inches.
Select Analyze > Fit Y by X.
Click OK.
6.
From the red triangle menu, select Equivalence Test.
8.
Click OK.
Figure 6.30 Example of an Equivalence Test
