Select Help > Sample Data Library and open Birth Death Subset.jmp
Select Analyze > Clustering > Hierarchical Cluster.
Select birth and death and click Y, Columns.
Select country and click Label.
This selection ensures that the country column, rather than the row number, is used to label the dendrogram that appears when you click OK.
Figure 10.2 Hierarchical Clustering Report
Figure 10.3 Constellation Plot
Help created on 10/11/2018
