Launch the Hierarchical Cluster platform by selecting Analyze > Clustering > Hierarchical Cluster. The Clustering launch window for the Birth Death Subset.jmp data table is shown in Figure 10.4.
Figure 10.4 Hierarchical Cluster Launch Dialog
(Available only if Data is stacked is selected as the data structure.) Specifies the variables that are stacked.
(Available only if Data are summarized or Data is stacked is selected as the data structure.) A column or columns that provide a unique identifier for each unit for which measurements are stacked.
Help created on 10/11/2018
