Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Y by X.
Select weight and click Y, Response.
Select height and click X, Factor.
Select sex and click By.
6.
7.
Hold down Ctrl, then select Fit Line from the red triangle menu.
Figure 4.48 Example of By Variable Plots
Help created on 10/11/2018
