JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Basic Analysis •
Bivariate Analysis
• Additional Examples of the Bivariate Platform
Example of the Fit Special Option
Example of the Fit Orthogonal Option
Example of the Fit Robust Command
Example of Group By Using Density Ellipses
Example of Group By Using Regression Lines
Example of Grouping Using a By Variable
Help created on 10/11/2018
