Select Help > Sample Data Library and open Variability Data/Gasket.jmp.
Select Analyze > Quality and Process > Measurement Systems Analysis.
Assign Y to the Y, Response role.
Assign Part to the Part, Sample ID role.
Assign Operator to the X, Grouping role.
Notice that the MSA Method is set to EMP, the Chart Dispersion Type is set to Range, and the Model Type is set to Crossed.
6.
Figure 7.2 MSA Initial Report
Figure 7.3 Parallelism Plot for Operator and Part
Figure 7.4 EMP Results Report
Help created on 10/11/2018
