The data in the Weight Measurements.jmp sample data table shows the height and weight measurements taken by 40 students.
Select Help > Sample Data Library and open Weight Measurements.jmp.
Select Analyze > Fit Y by X.
Select weight and click Y, Response.
Select height and click X, Factor.
Figure 4.45 Example of Robust Fit
Help created on 10/11/2018
