JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing •
Graph Builder Examples
• Example Using Images as Markers
If you want to use images as markers or points in a graph, you can add an expression column containing the images to your data table, then use that column in Graph Builder. For an example, see
Use Images as Markers
in the
Using JMP
book.
Help created on 10/11/2018
