Figure 7.5 Example of Three Random Distributions
Max(0,RandomNormal(5,2))
After entering the expression, click the Reset button to submit the expression.
Figure 7.6 Defining a Correlation Matrix for the Multivariate Option
Many of the distributions available use standard random functions that are described in Random Functions in the Using JMP book. Descriptions of the specialized distributions available follow:
Help created on 10/11/2018
