JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Fitting Linear Models •
Generalized Regression Models
Generalized Regression Report Window
• Generalized Regression Report Options
Model Dialog
Shows the completed Fit Model launch window for the current analysis.
Set Random Seed
Sets the seed for the randomization process used for KFold and Holdback validation. This is useful if you want to reproduce an analysis. Set the seed to a positive value, save the script, and the seed is automatically saved in the script. Running the script always produces the same cross validation analysis.
Save Coding Table
Creates a new data table whose first columns show the JMP coding for all model parameters. The last column shows the values of the response variable. If you specified a sample size column for a binomial response, both the response and sample size columns are shown in the table. If you used two response columns to specify censoring, both response columns are shown in the table.
Note:
The coding data table contains a table variable called Original Data that gives the name of the data table that was used for the analysis. In the case where a By variable is specified, the Original Data table variable also gives the By variable and its level.
See
Local Data Filter
Redo Menus
, and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
Help created on 10/11/2018
