Open a new Script window in JMP by selecting File > New > Script (Windows) or File > New > New Script (Macintosh).
To import all text from the Script Editor, select File > Import as Data (Windows) or Edit > Import as Data (Macintosh).
To import specific text, select the text, and then select File > Import as Data (Windows) or Edit > Import as Data (Macintosh).
Help created on 10/11/2018
