Another option is opening a JMP add-in definition (.def) file as text and then editing it in a Script window.
Files that you recently opened are listed in the JMP Home window. For most files, right-click the text file and select Open as Plain Text to open the file in a text editing window. JMP add-in definition files cannot be opened as plain text from the JMP Home window.
Select File > Open.
To open a JMP add-in definition file as text, select All JMP Files or JMP Add-In Files from the list next to File name. Click the Open button arrow, and then select Open as Plain Text. The file opens in a Script window. Skip the remaining steps.
To open other text files, select Text Files from the list next to File name.
Figure 2.51 Select Text Files
(Optional) To set the default option file type to Text Files, select the check box beside Select this filter the next time this dialog is invoked.
Select Plain text into Script window next to Open as.
6.
Click Open.
Select File > Open.
Figure 2.52 Opening a Text Document on the Macintosh
Click Options.
Select Text from the Open As list.
Click Open.
Help created on 10/11/2018
