Select Help > Sample Data Library and open Big Class.jmp.
Select Analyze > Fit Model.
Select weight and click Y.
Select age, sex, and height and click Macros > Factorial to Degree.
6.
Click Run.
7.
Note that the test for age has 15 degrees of freedom. This test involves the five parameters for age, the five parameters for age*sex, and the five parameters for height*age. The null hypothesis for this test is that all 15 parameters are zero.
Figure 2.33 Joint Factor Tests Report
Help created on 10/11/2018
