Select Cols > Label/Unlabel from the menu or right-click and select Label/Unlabel.
Select Rows > Label/Unlabel from the menu.
Select Label/Unlabel from the Rows menu or Cols menu. You can also right-click columns or rows and select Label/Unlabel.
Tip: A photo can be displayed in the label when you place your cursor over data. For example, the SAS Offices.jmp sample data table contains an Expression column that is labeled. A photo of each office is stored in the column. When you place your cursor over a data point on the map, the photo for that row appears. See Expression Role in The Column Info Window for details.
Help created on 10/11/2018
