JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability and Survival Methods •
Destructive Degradation
The Destructive Degradation Plot Options and Models
• Plot Options
Plot Options
Distribution
Choose a location-scale or a log-location-scale distribution.
Transformation
Choose a transformation function for the response
Y
and for the
Time
variable.
Note:
If you apply the Log or Sqrt transformations to a column that contains nonpositive values, the rows with nonpositive values are omitted from the model fit.
Path Definition
Choose a linear or a nonlinear path for the regression model. For details about each model, see
Models
Generate Report
Creates a report for the specified model. The first time you select Generate Report, a Model List outline is created. When you select Generate Report to fit other models, the Model List outline is updated and an outline is added for each model.
Help created on 10/11/2018
