JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Quality and Process Methods •
Multivariate Control Charts
Multivariate Control Chart Platform Options
• Principal Components
The Principal Components report contain the following information:
Eigenvalue
Eigenvalues for the covariance matrix.
Percent
Percent variation explained by the corresponding eigenvector. Also shows an accompanying bar chart.
Cum Percent
Cumulative percent variation explained by eigenvectors corresponding to the eigenvalues.
ChiSquare
Provides a test of whether the correlation remaining in the data is of a random nature. This is a Bartlett test of sphericity. When this test rejects the null hypothesis, this implies that there is structure remaining in the data that is associated with this eigenvalue.
DF
Degrees of freedom associated with the Chi-square test.
Prob > ChiSq
p
-value for the test.
Eigenvectors
Table of eigenvectors corresponding to the eigenvalues. Note that each eigenvector is divided by the square root of its corresponding eigenvalue.
For more information about principal components, see
in the
book.
Help created on 10/11/2018
