Profilers
Figure 10.18 Distribution
Enter a value for Survival Time to indicate the time to which the system has survived without failing. As an alternative to entering a value, select the small rectangle at the origin of the graph and drag it to the right to dynamically set the Survival Time.
Figure 10.19 Remaining Life Distribution
Figure 10.20 Cumulative Hazard
Help created on 10/11/2018
