JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Reliability and Survival Methods •
Reliability Block Diagram
• Options for Design and Library Items
The available options for Design and Library items are listed below:
Show Configuration shows or hides the Configuration outline. See
Configuration Settings
Options to show various profilers. See
Profilers
and the following:
Distribution Profiler
Remaining Life Distribution Profiler
Reliability Profiler
Quantile Profiler
Density Profiler
Hazard Profiler
Cumulative Hazard Profiler
Options to show plots for component importance measures and mean time to failure. See
Component Importance and Time to Failure
and the following:
Birnbaum’s Component Importance
Remaining Life BCI
Component Integrated Importance
Mean Time to Failure
Options to show overlay plots for the components in a system diagram. See
Component Plots
and the following:
Component Distribution Functions
Component Reliability Functions
Component Density Functions
Component Hazard Functions
Component Cumulative Hazard Functions
Print Algebraic Reliability Formula
Clone and Delete
Help created on 10/11/2018
