To use ranges, click Allow Ranges then specify the lower and upper values. If Allow Ranges is selected, Value Labels can be non-integers. Graph Builder can use the Value Labels for the x- and y-axes.
Tip: To assign a label to missing values, enter a period (.) for the lower bound and leave the upper bound empty. To assign a label to all other values, enter three periods (...) for the lower bound and leave the upper bound empty.
Tips:
To turn off value labels in the data table without deleting the value labels that you have set up, in the Column Properties window, deselect Use Value Labels. Or, to quickly show or hide value labels in a data table, right-click on a column and check or uncheck Use Value Labels.
When your data table contains value labels, using the Search commands searches for actual values, but does not search for labels.
When your data table contains value labels, the Row Editor displays the label, and when the cell is highlighted for editing, it shows the actual value.
From the Column Properties list, select Value Scores.
Click Add, Change, or Remove.
6.
To use a color theme, click Color Theme below the list of value colors and then select the color.
Click Color Theme below the list of value colors in the column properties.
Click New.
6.
To also color the cells in the data table, select Color Cell by Value above the list of value colors.
Help created on 10/11/2018
