Select File > Database > Save Table.
Note: Remember the name for the database table. You use this same name for the replacement database table.
Click Drop Table.
6.
From the JMP data table to be saved list, select the JMP data table that you want to save to the database.
7.
In the Save to database table box, enter the name for the deleted database table.
8.
Click Save Table.
9.
Click Disconnect.
