On Windows, select File > Save As to save in multiple formats.
On Macintosh, select File > Save As to save as a JMP file (.jmp). Select File > Export to save in Text (.dat), Microsoft Excel (.xls or .xlsx), SAS Transport (.xpt), and SAS Data Sets (.sas7bdat) formats.
Note: To save a data table as a journal, select Edit > Journal and then File > Save As.
Excel Workbook (.xls, .xlsx)
SAS Data Set (.sas7bdat)
Note: JMP can save column properties and table properties as extended attributes in a SAS 9.4 .sas7bxat file. Select File > Save As, select the SAS Data Set file type, and then select the check box for saving extended attributes. JMP names the file with the .sas7bxat extension. The SAS Integration preferences also include this option, which is off by default.
JSON (.json)
Notes:
Help created on 10/11/2018
