Save and Share Reports
You can save the report as a journal by selecting Edit > Journal and then File > Save.
If you want to save the report as a text, image, HTML, PowerPoint, or RTF file, select File > Export. Supported image files include .eps, .png, .svg, .pdf, and .tiff.
Line drawing (or vector image) that can show a bitmap preview of the image.
Interactive HTML (.htm, .html)
Note that on Macintosh, select Edit > Journal, and then File > Save. On Windows, choose File > Save, and then choose the journal format.
Help created on 10/11/2018
