Save one data table in Microsoft Excel format (.xls or .xlsx). Data from a single table is saved in a workbook named after the data table.
Generate a workbook in .xlsx format from multiple tables. Data from each table appear on a different worksheet in the workbook.
The .xlsx file includes data table cell colors. The file also provides hidden data and excluded data. Formulas and most formatting are not included.
Select File > Save As.
Select Excel Workbook (*.xlsx, *.xls).
(Optional) To save the file as an .xls file, select Use Excel 97-2003 Format (*.xls).
6.
Click Save.
Select File > Export.
Select Excel and select the format.
Click Next.
6.
Click Export.
(Windows) Select File > Create Excel Workbook.
(Macintosh) Select File > Export, select Export Multiple Data Tables from the Excel list, and then click Next.
7.
Click Choose and browse to select a directory to save the file in.
8.
Click Save.
Help created on 10/11/2018
