Select the radio button next to the character that marks the end of a field (or cell). Select Other and enter a character if the appropriate character is not listed.
Select the radio button next to the character that marks the end of a line (or row). Select Other and enter a character if the appropriate character is not listed.
Notes:
Select File > Save As.
Select Text Export File from the Save as type list.
Click the Options button and specify end-of-line and end-of-field characters, and choose whether to export column headings as text.
Click Save.
7.
Click Yes.
Select File > Export.
Select Text and click Next.
Enter a name for the file in the Save As box and change the extension to .txt.
6.
Click Export.
Help created on 10/11/2018
