You can save part of an analysis report window as a graphic. You can save the selection in .png, .jpg, .gif, .eps, .emf, .pdf, .tiff, and .svg formats. On Macintosh, you can save the selection in .png, .jpg, .gif, .svg, .eps, .pdf, and .pptx formats.
On Windows, select Edit > Save Selection As. On Macintosh, hold down the Ctrl key and select File > Save Selection As.
Select Select this filter the next time this window is invoked to save your file type selection for the current session.
6.
Click Save.
Tips:
Pref( Save Image DPI( 600 ) );
When you export a graph or report that contains a bitmap image to an .svg file, the image is embedded in the .svg file. The exported content is then easier to reuse in other documents.
Help created on 10/11/2018
