JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Quality and Process Methods •
Cause-and-Effect Diagrams
Save the Diagram
• Save the Diagram as a Data Table
Note the following about this approach:
If you have other processes that need to update the data table, this can be a good approach to choose.
Very little customization is available, because the data table cannot represent the customization.
To save the diagram as a data table:
Highlight the entire diagram.
Right-click and select
Make Into Data Table
Save the new data table.
Help created on 10/11/2018
