JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Quality and Process Methods •
Cause-and-Effect Diagrams
Save the Diagram
• Save the Diagram as a Journal
Note the following about this approach:
This option can be a good choice for impromptu work. For example, you can manually build the diagram, save it as a journal, then reopen the journal later and continue building and editing the diagram.
Any customization exists only in the journal, and the journal is not connected to the data table.
To save the diagram as a journal:
Highlight the entire diagram.
Right-click and select
Edit > Journal
Save the new journal.
Help created on 10/11/2018
