JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Enter and Edit Data
Assign Characteristics to Rows and Columns
• Select Matching Row State Cells
You can select a cell in a row state column and then select all cells that contain the selected cell’s attributes. This option enables you to select cells with any combination of row state attributes, such as Exclude, Hide, color, or marker. For example, if a cell has a red marker and is excluded, and you select matching cells, all cells in excluded rows with red markers are selected.
Right-click the cell whose row state you want to select.
Select
Select Matching Cells
The cells with matching row states are selected.
Help created on 10/11/2018
