JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Multivariate Methods •
Multiple Correspondence Analysis
Multiple Correspondence Analysis Platform Options
• Show Detail
Show Detail
Shows the table of singular values.
Singular Value
Shows the singular values in the singular value decomposition of the contingency table or Burt table. For the formula, see
Details Report
Inertia
Lists the square of the singular values, reflecting the relative variation accounted for in the canonical dimensions.
ChiSquare
Lists the portion of the overall Chi-square for the Burt or contingency table represented by the dimension.
Percent
Portion of inertia with respect to the total inertia.
Cumulative Percent
Shows the cumulative portion of inertia. If the first two singular values capture the bulk of the inertia, then the 2-D correspondence analysis plot is sufficient to show the relationships in the table.
Help created on 10/11/2018
