Provides correspondence analysis reports. These reports give the plots, details, coordinates, and summary statistics. See Additional Examples of the Multiple Correspondence Analysis Platform.
Provides the Burt table or contingency table as appropriate for variable roles selected. See Cross Table.
(Available only when a supplementary variable is specified.) Provides a contingency table of the supplementary variable(s) versus the response variable(s). This table appears by default only if a supplementary variable has been specified in the launch window.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
