The Space Filling augmentation choice adds points to a design consisting of continuous factors. For details about the algorithm used, see Statistical Details. The Space Filling choice accommodates constraints on the design space. You can specify linear constraints or disallowed combinations.
Select Help > Sample Data Library and open Design Experiment/DOE Example 1.jmp.
Select DOE > Augment Design.
Select Depth and click Y, Response.
Select Speed and Current, click X, Factor, and then click OK.
6.
Select Specify Linear Constraints and click Add.
7.
Enter 1 for Speed, select greater than or equal to, and then enter 4 for the lower bound on Speed.
8.
Click Add.
9.
Enter 1 for Current, select greater than or equal to, and then enter 155 for the lower bound on Current.
10.
Click Space Filling.
12.
Click Make Table.
14.
Drag Speed to the X drop zone and drag Current to the Y drop zone.
Figure 5.18 Space Filling Augmented Runs
Help created on 10/11/2018
