Select Cols > Standardize Attributes.
Select Column Properties in the Standardize Properties area.
Click Apply to standardize the property across selected columns. Changes are shown in the data table, open reports, and open graphs.
Or click OK to standardize the property across selected columns and close the column properties window.
Help created on 10/11/2018
